21 - 40 of 47 Posts
It looks like the metal washer (its more of a metal seat than a washer) that sits on top of a mounting perch halfway down the strut shaft has broken. (Its what keeps the strut from popping up through into the passenger compartment like that). You'll have to take the strut assembly off the car to remove the dust cover to see if thats the problem.
You have a lot of rust issues? I've never seen one break like that, I'm thinking maybe it was really badly corroded and finally became weak enough to break.
No, a new shock mount will NOT fix that problem. It looks like you tore up a washer or something. You really did some damage there man driving without that bolt.
You'll have to disassemble the shock and replace that washer, assuming nothing else is broken.
Well, since you shouldn't be driving your lude with the rear suspension in the condition it's in, pull that shock/spring combo out the car and take pics of the top of it (remove the 10mm nuts and the mounting piece and shock/spring combo should come out. You'll have to remove the lower fork bolt too of course). I have a feeling that you'll need another top shock mount. One from a junkyard should do as long as it's in decent condition.
I think that the washer that Mario is talking about is part of the upper shock mount. I had the same thing happen to my 85 Grand Am I used to have. When I hit a bump, it'd knock the top of the shock into the trunk and make this aweful noise! It was like 13 for a new one from the dealer...
Discussion starter · #33 ·
ok here is some more info on the problem hopefully it helps someone. ok well i just went and looked at the suspension all around the car and on all the other shocks and i cannont see the piston on the shcok...well except the rear pass. side. anyone know why that would be???
EDIT: im looking into the wheel wells from the outside
That's because you busted the top part of the shock's dust cover where the washer is. It's hard to explain but you need to get a washer and put it on the top of the shock. When we dropped a buddies car, we had to cut/pry the washer off of the top of the upper shock dust cover, otherwise the shock would do what yours is doing.
It's all clearer to me know but trying to communicate it to you is difficult. Best thing for you to do is to take off both sides and compare the shocks on both. THen you'll see the difference and what you have to fix.
Man I wish I had some pics...
By the way, and sorry I didn't see this posting earlier (and so won't confuse the situation), there was another member who had exactly this problem - I wasn't about to go looking for the thread - but I do remember this entire scenario. So it's not that abuse only causes this, sometimes it just happens (agreed rare).
It was me who it happened too... I posted a pic of it as well, with the piston sittin 3" in the engine bay. :)
21 - 40 of 47 Posts
