I want to know what is your experience whit tein flex and what iis the best price u get for base model thanks
Really?? I can turn the dampening screw 24 clicks!the tein flex is great but just to correct JDLUDE99 statement regarding the number of dampening levels. The flex has 16 dampening levels of adjustments without the EDFC. If you are using EDFC with your flex, it will then have 32 levels of dampening adjustments due to the fact that the EDFC has the capability to do half turns between each level therefore doubling the levels of adjustability
With all of the items that come with your coilovers the damper is the most expensive part that comes with the kit. A lot of companies promote the # of adjustment "clicks" on their dampers as a feature, without posting a dynograph of the adjustment range of that damper. Well it’s time to start questioning why. Because "32 way adjustable" really tells me squat about the damper other then it is supposedly adjustable. It doesn’t tell me what gets adjusted, it doesn’t tell me the range in which those things get adjusted in
Most if not all of these "coilover" companies run single adjustable dampers that adjust both bump and rebound with the same knob, which is silly for any sort of tuning for handling. The dampers they do run adjust mostly in the mid speed valving range, limiting their usefulness for anything other than tweaking your ride quality.
Sure “pre-built” coilovers are easier. They are very convenient and the car handles better than stock but not as well as it could. With a bit of luck someone else has “tuned” the coilover to your car. Will it be tuned specifically for you, no. They are tuned for a wide variety of customers with many different wants out of a suspension kit.
