Oil Leak help
1 reading
2.3K views 3 replies 3 participants last post by  SteppinRazor
#1 ·
Hi all. I have an oil leak I can't find the source of.
So far I have replaced:
VTec solenoid gaskets
Distributor o-ring
Camshaft seals
Oil cooler O-ring
Valve cover gasket
and have pulled the oil pressure sender and sealed the threads
I have oil dripping onto the flex pipe of the exhaust. I can see the oil dropping off the oil pressure sender cover. So I pulled it, sealed it and put it back in. No dice. Replaced the oil cooler O-ring because it's right above it. No dice. Above that are the valve cover gasket/distro/vtec solenoid. No dice. Where else can it be coming from? I thought maybe rear main seal, but it looks to be too far to the right and too low to be dripping from the oil pressure sender. I'm at a loss, any ideas would be appreciated. Thanks
#2 ·
oil pressure sender internal failure ?....clean the crap out of everything and it should be easier to see leak...send picture ? (not sure that will help though)...i had a not good leak, replaced vtec gasketS,now livable leak...drip...i wouldnt chase ghosts...how bad is leak?
#4 ·
Thanks guys. I've cleaned it all, still can't see a definitive source, other than I see it dripping off the oil pressure sender. Tried ordering a new oil pressure sender, but they are on back order (waited 11 days before I called and was informed that). It's all clean up top and all seals/gaskets/o-rings replaced topside.
#31 on this is the oil pressure sender. Does anyone know what #32 is?
