JDM h22 cold start problem
12K views 18 replies 12 participants last post by  $m0oth_h22a
#1 ·
I dont know if this is a common thing with h22, but when its cold out side or the car hasnt been running in over 5 hours it takes a while to start it. I thought it might have been the battery so I swaped the battery with a new one and it still has the same problem. Before when the car was an automatic h23 i never had any problems starting in the cold even with my cold air intake.
#2 ·
I have had the same problem, I am not driving the car this year but I had the H23 before the H22A swap, and it worked fine. The JDM H22A doesnt like the cold i geuss, Im sure there is a reason for it...
Just letting you know your not alone, sorry I couldnt help
#3 ·
Um, just throwing something out there but your fuel pressure at the rail could be bleeding down and causing an extended crank. It could be many things causing this but I guess it is up to you whether it is worth the money or diagnostic time.
#18 ·
how long is "a while"? since its been cold mine usually takes about 5 to 6 secs but i dont think thats long enough to worry about
Its the worst in the morning, take me about 3 min of on off cranking. Once the car has been started i have to give it some gas to keep it from dieing. The rest of the day its fine unless is has been not running for more that 5-6hours. I added some heet to the gas tank, kinda helped but I noticed when I prime the fuel pump on and off a few times it started up a little faster, about 1-2min to start.
#8 ·
Mine did the same thing. Took me a min or two of on-off cranking to get it going. It only happened when extremely cold out and it had been sitting long enough to cool off. I'm gonna try a new main relay. Other than that I've had two people say the same thing as nbimprtlude20 to me. If the relay doesn't work I'll investigate that more.
#12 ·
mine hates to start too, after cooling off. regardless of temeperature.
if it ran an hour before, starts right away. if not, it cranks a few times before it fires. it's annoying.
#13 ·
Well my lude is in Houston so I never have that problem obviously. Out here in Ohio I bought a t-bird with a boss 302 and when it gets cold I have to use some starting fluid and let it warm up for a few minutes at around 1500 rpm or it will die. The guy that sold me the car said it's because it's got high compression pistons. I know that h22a's are high compression with like what? 9:1? So that may have something to do with it...
#16 ·
I changed my ECT sensor yesterday and i was able to start right up in the cold. It was 29 degrees F when i left for work and it fired right up.. have to press gas still.
