4WS and ATTS system on the same Lude?
3.5K views 27 replies 20 participants last post by  HiFiSi
#1 ·
Is this even plausible? I mean I know anything is possible. But what do you think the result would be? I think it could be very interesting to see the results. I think it would add too much weight. What do you guys think?
#5 ·
huh?
His is 4ws, not ATTS equipped.
Like Bdogg said, seems how both need a specific ECU, you would have to have an ECU designed for both. Not to mention that I imagine the ATTS would have some issues with 4ws.
I personally dont think having both would be a good thing.
#3 ·
Interesting, but a whole lot of work, for how much gain? It would be easiest to swap a full SH drivetrain and such into a 4th gen with 4ws, but an lsd tranny would be as usefull, especially since the 4th gen is that much lighter than any 5th gen, especially an SH.
#6 ·
doesnt 4WS have it's own ECU in the trunk? I dont think it would be too hard to do this, just do an SH drivetrain swap into a 4WS lude. People do the SH to base conversion, why not the reverse? I dont have an SH so I dunno, does ATTS have a separate ECU or does it use the main ECU? If they are all separate I see no reason why they would conflict with each other...
#19 ·
Well... not 100% on this but, if the 4WS ecu is obd1 and the SH ecu is OBD2 I can't see how that would be compatible.
Is there OBD2 complient 4WS? I have no clue if 5gens offer 4WS, maybe one of the euro models might.
#20 ·
Anything is possible with a little bit of work... I don't see why there would be a physical problem... of course I don't know any details about the 4ws such as when it turns the wheels or not... like does it do it at any speed? i saw yella's video of him turning in the parking lot and it turns parked but what about on the highway and stuff to help change lanes smoother?? i know some cars nowadays do it like the g35 and all that... the rear wheels turn up to 1 degree i believe which helps handling at high speeds.
#23 ·
i think the most realistic way (although it wouldn't be worth the money or even necessarily an improvement) would to fabricate a completely mechanical 4ws system like the 3 gens have and mate it to an already sh lude (or acura for that matter.) that way you don't have the ecu problem.
#26 ·
Not really... the 3rd gen had mechanical... but you would basically have to replace all the steering and rear suspension components for it to work on a 4th or 5th gen prelude, if that is even realistically possible... The ones that came on the 4th and 5th gens were electrical.
