101 - 120 of 185 Posts
^ i was wondering this too. i just ordered my projectors today and will hopefully have the time to do this in the next couple weeks.. so i guess there's two options for mounting: 4 bolts, or center post? all i've seen on how to do it is on this thread with the center post. how would the 4 bolts option work?
Well I just did one of my headlight retros last week, and I gave it a good shake to make sure the projector wouldn't shift and was satisfied with the result.
^Finished picture.
It's a bit tough to see, but next to each of the screws that holds the plastic portion of the projector to the metal portion, there is a separate screw hole. Perhaps that's where the 4 bolts jlude mentioned would go, though it would require removing the reflector housing from the headlight assembly to do properly.
Oh, also SHIMEE!!! Note the tab on the plastic portion? Those tabs are responsible for holding the lens in place, though I did notice that if you line up the tabs on the shroud with those, the shroud can be removed and installed with no additional effort.
so you used the center post mounting method? ok good, seems that's what i'll do also. not sure if i'd want to take apart the headlight more than necessary..
Looks like your question has been mostly answered but the projectors come predrilled with 4 mounting holes that will fit a #8 machine bolt through. I simply cut out a hole in the center of the low beam reflector about 1.75" diameter and stick the projector through, get it aligned as closely as possible and then use a finishing nail to stick through each of the 4 mounting holes and mark the spot in the headlight reflector to drill a hole. Next you drill out the 4 holes and use a dremel with a small grinding pin to widen each hole and test fit the projector till all 4 holes are in the correct position. I make each hole about 4 times wider then the machine bolt in order to fit some play to adjust projector rotation and alignment before tightening down the 4 bolts using washers and lock nuts. If done right the projector is solid as a rock and will never move from vibration. This is the same way I mount FX35, TSX and RX330 projector retrofits and has always worked well. It may take a little more time but you end up with a rock solid mount.
  • Like
Reactions: camel_89si
nice! :thumbs-up:
awesome, thanks jlude i'll definitely consider doing this during my install. a friend of mine is going to help me with this and he's a lot handier than i am, but neither of us have done a retrofit before so we can use all the advice we can get! thanks again
hey ok so sorry to keep bumping up this thread haha but what's the best way to reseal the headlights? the butyl rope? shouldn't it be clear? i was thinking automotive grade clear silicone but if that's not the best then i wanna use what's right the 1st time and never have to worry about it.
and if butyl rope is the best, where should i go about purchasing some?
Definitely butyl sealants are best as they get tacky when heated, allowing a good, water tight seal when you re-install the headlight lenses.
Autozone and most other autoparts stores carry it...it will be near the sealants and it's usally the "3M WINDOW WELD" product. It's made for windshields but it's the same stuff used for headlight lenses, only problem with Window Weld is it's about $16 and has enough butyl for about 10 headlight jobs!
What bulbs would have the most output the d2s bulbs or the h1 bulbs?
There's some comparison pics in this thread.
http://www.hidplanet.com/forums/sho...ums/showthread.php?27287-Bi-Xenon-Output-Comparison-TL-E55-Murano-FX-IS-e46-LR3
And from the man himself.
For the most part, the performance of the Mini D2S and Mini H1 projectors is even, but I will highlight some of the small differences below:
1) Beam uniformity: The Mini D2S is a bit better in this category, with slightly more even-ness in its output.
2) Beam Width: The Mini H1 is slightly wider here
3) High beam performance: The Mini D2S has a brighter, more defined high beam (bi-xenon) output
4) Cutoff color/sharpness: The projectors are even, since they use the same exact lens - giving them a sharp and colorful cutoff line.
5) Bulb type used: Obviously the H1 takes H1 and D2S takes D2S, and we feel that D2S bulbs offer a bit more precision, though no more light.
6) Size: The D2S version is about 1/2" shorter in overall depth, but is also barely wider and a little bit taller than the H1 version.
7) Modification to your OEM housing: the diameter of the mounting shaft on the H1 is 22mm, whereas it's 32mm on the D2S model, so you probably wont have to modify anything at all when using the MH1, whereas you will likely have to just widen the diameter of the existing bulb opening to use the D2S projector.
Therefore, if you value the categories more than the H1 wins, you should probably go that route - and vice versa for the D2S model.
Personally I just "like" the D2S model more since I favor the categories that it outshines the H1 model more in, but ultimately its up to you - since both should fit your vehicle with little to no modifications at all.
okay this might be a stupid question but i will be attempting this in the next month because i feel fairly confident i could do this. so did you guys use a dremel to cut the hole? or did you guys drill the hole?
I haven't done them but I wouldn't use anything else other than a dremel. You need to have good control,a lot harder to do with a drill.
Sent from my DROIDX using Tapatalk
You can use a drill with a grinding bit to enlarge the hole, a small angle grinder works great too but the dremel is still easiest to use.
Discussion starter · #117 ·
The camera exaggerates the exposure but the cutoff really is that colorful. I could also do the retrofit for you if you'd like.
okay one more question i just ordered the projectors and hids. but i was wondering if the stock adjustment screw still works, with the projectors in? like can i adjust the up and down with the screw or do i have to move the projector to adjust?
to my understanding, when you mount the projector you want to make sure the beam is level. once everything is installed you can use the stock alignment knobs to align to you preference.
correct me if i'm wrong...
can't wait to do my retro! hopefully will be doing it this monday!
^thanks, now i just got these in and have yet again another question haha, but for the shrouds shimee had ones with the tabs but the ones that i got no longer have the tabs so what would you guys suggest to hold them on tightly now? thanks
