Front Radiator Support
3.1K views 6 replies 5 participants last post by  NightHawkLude
#1 ·
I am needing to replace my front radiator support (front bulkhead). I can see on the origianal one that needs to be replaced that it is spot welded togeather, but what I am wondering before I get into it is if it is welded to the car or is it just spot welded and bolted to the car. Any help is appreciated.
Thanks
#2 ·
spot welds is the same as being welded to the car :p what you need to do is drill out all the spot welds, then weld on the new radiator support. There are no bolts holding it on at all
