check out this!!!!!
1992-2001 Honda Prelude
Combo Air Suspension Kit
Combo Kits Include Front Kit, Rear Kit and 4 Path Air Management System
Lower your Prelude, improve your handling, and get control over your suspension. The most versatile choice for suspension on today's market. Go from the strip to the street to the show floor with the push of a button. Our air struts kits are designed to give you maximum performance with our 9-way adjustable dampening system previously only found on high end coilovers. Want to adjust your spring rate as well? No coilover will ever offer this option! Adjust your spring rate with the flip of a switch. When style matters just as much as performance, our air struts won't let you down. Wheel gap never helped anyone win a car show! Tuck those rims up where they're supposed to be. This kit will set you on the ground, let you clear speed bumps, and get in and out of driveways without scraping your ride. Not to mention the remarkably smooth ride that air provides.
Kit Includes:
- 2 Front 9-way dampening Air Struts
- 2 Rear 9-way dampening Air Struts
- 8 3/8" exclusive chrome 300 PSI Valves
- Viair 380C Chrome Compressor
- 5 Gallon D.O.T. Approved Air Tank with 8 1/2" Ports
- 2 200 PSI Dual Needle Gauges with Chrome Bezels
- 40' of 1/2" D.O.T. Approved Air Line
- Nickel plated D.O.T. push to connect fittings
- 145-175 PSI Pressure Switch
- 4 Switches
- 50' of 1/4" D.O.T. Approved Air Line for your Gauges
- 90' of 16 Gauge Wire for Proper Valve Connections
- Detailed Installation Manual
- 1 Year Warranty against Manufacture Defects
Part #: Y000_EZS85734-SN
List Price: $2,350.00
Our Price: $2,219.44
if i were to get any thing it would prob be this kit
