MAN THESE ARE SWEEEEET!!! I took an old used (and yes broken to) set of B21 motor mounts and filled them with 3M Windshield adhesive. Its a $13 (from advance) tube of caulk. All you have to do is fill the mount push the adhesive into the small areas and make sure to get all the air bubbles out, then smooth out the top surface and let it dry. 1 tube will do all 4 mounts.
My good friend Brad and I got them all put in the car in about 2.5 hours. They make the car so much easier to drive with the 7.5 lb fly... I was super suprized that it feels different shifting, but it feels way different. Shifts are extremly smooth it almost feels like an automatic!
It also handles differently/better, its much crisper and tight going through the corners.
Yes I do have a bit more vibration. Actualy with all 4 filled mounts installed it was way to much vibration even after raising the idle a bit. I set the idle at about 900 so that the vibration wasnt to bad at idle. But with all 4 filled mounts installed my hands were almost numb when I got to work after my 1 hour drive.
So last night i put back in the Drivers side mount and now its hardly any different feeling than sock. Yes I do have more vibration at idle but once you get moving it feels very very close to stock.
I recomend anyone with lightend flys or performance mods add this to their Lude. It makes a HUGE difference. I will have a spare set (b21) for sale if anyone is interested. PM me for details.
