So I am replacing and rebuilding the A/C in my 88 Si. New compressor, exp valve, condenser, evaporator, drier, discharge line, suction line, o-rings, ester oil...
Alright so which is better. I understand the R-134a needs a higher PSI to function, and it is thinner, so leaks easier. However, the Freeze-12 is actually a mixture of R-134a and some other R-# freon-based stuff, but operates at a lower pressure. Also, supposedly the Freeze-12 only needs 90% of the quantity that R-12 needs to operate the same. The thing is, Freeze-12 is more expensive than R-134a...
What has worked for you? What are the pros/cons of each?
