Here she is.
I am rebuilding my motor because my oil cooler line split open at 7,000 rpm. The motor is still in the car but on its way out soon. Damage is unknown but if I had to guess its a spun rod bearing. While I have been slowly pulling the motor I have been working on some side projects. They are a custom carch can setup, wire tuck, new recirculated downpipe and a custom intake manifold. Who knows I might even throw in some custom spec crower cams toward the end of the build. More to come soon and yes there will be lots of detailed pictures and specs on everything I do for all to learn.
My seriously injured motor.
Performance
Engine
Je pistons 8.5:1 custom
Je rings low tension moly coated
Eagle h22 rods
Darton iron sleeves
Balanced rotating assembly
Stainless steel o-ring set in sleeves
Full port and polish
3 angle valve job
Swirl polished valves
JG valve springs good for 8,200 rpm
AEM cam gears
2,300 lb pressure plate and 6 puck ceramic disk clutch
Clutchmasters 9lb flywheel
c-n-s aluminum radiator
r5671a-8 plugs .028 gap
Walbro 255 fuel
pump
Ari fuel pressure
regulator with liquid filled gauge
4” intake with K-n-N filter
Custom 3” exhaust with apex N1 and flex pipe aluminized steel
Bored stock throttle body 64mm
Xs Engineering t04x/t3 turbo
Xs Engineering silvia core intercooler 20”x12x3
Greddy profec b electronic boost controller
Greddy turbo timer
HKS ssbov
HKS gt wastegate
SFP turbo manifold
2.5” intercooler piping
3” downpipe
MSD 1006cc injectors
P72 ecu chipped with ectune
Gm 3 bar map sensor
Prodrive modified oil pump with billet steel gear
Prothane motor mounts
Egr eliminated
Balance shafts eliminated
Secondary butterflies removed
Performance
Engine
Eagle h22 rods
Darton iron sleeves
3 angle valve job
AEM cam gears
Walbro 255 fuel
Ari fuel pressure
Greddy turbo timer
HKS ssbov
HKS gt wastegate
SFP turbo manifold
3” downpipe
Gm 3 bar map sensor
Egr eliminated
