in my case it was not necessary to think that I did something wrong?You might need to modiffy the radius rod for pulley clearance:
I built a new wiring for the part of the engine that handles a plug inside the car. I removed the plugs from an old ECU so I don't have to cut the wires in the car. If you didn't notice, I try to explain it in another way so you can understand.Looks good. Can you explain what you are doing with these wiring ?![]()
My guess is you are making OBD0 to OBD1 or something like that. No idea about those jumping wires and most of it... but looks good thoughI built a new wiring for the part of the engine that handles a plug inside the car. I removed the plugs from an old ECU so I don't have to cut the wires in the car. If you didn't notice, I try to explain it in another way so you can understand.
I'm doing obd0 for obd2b and an original h22a7 ECUMy guess is you are making OBD0 to OBD1 or something like that. No idea about those jumping wires and most of it... but looks good though![]()
Nice, what electric powersteering system did you use?
