1 - 8 of 8 Posts
Yup. The title is correct. Most people dont want to see a check engine light. In my situation, I want to see it because i was suppose to use that light for diagnostics, shift light, and a 2 step launch control with hondata. So now without that, I cant use it and the shop wants me to pay an arm and a leg for it.
Any Ideas on how i can resolve this? Could it be that some relays under the dash had failed? I replaced the clusters twice because i thought that could be the problem but still no luck. Also, my gas light doesnt work because i was curious and kept driving the car until it started to sputter to realize the light doesnt work.
Tips on removing the cluster.
Hey there... I just went through that... To replace the Check Engine Bulb, you need to go to your local parts place and buy the smallest bulb they sell retail... its like #78 or 79 or something... Then you have to remove the cluster and COMPLETELY disassemble it. Be VERY careful with everything, if you drop something or short something, your guages will never work the same. ( I broke my Temperature gauge some how and I was VERY careful and I am an expert at taking it apart.) The local salvage yard here has new SI clusters for 80$, In hindsight, I kind of wish I just bought a new cluster at first instead of replacing the bulb... There is a service manual online available that takes you step by step on removing the cluster, and taking it apart, but I will give you some insight: Make sure you pull out the dimmer switch, and the fog light switches first, and get the two screws with a long Phillips magnetic screwdriver behind them before you pull on the dash or you'll break the panel. There are three screws on the top you need a short Phillips to reach, then you just pull towards you. (There are 4 clips that may fall out when you pull (put them back before reinserting, and any of the three speed clips may fall out of the top three.)
sounds like an issue with how you did the obd1 conversion, specifically the wiring at the ecu plugs
x2..
jdm3genprelude: Did you try to pm me as well? Your name was listed on my non recieveid PM's this week. Send away as my PM box is clean again.
when i first did the swap, it was working fine. i remembered everytime i hit the rev limiter, the check engine light would come on. and then one day i did it again and no check engine light. thats when i changed out the clusters twice, the circuit board when the bulbs are mounted on to, and even swap the bulbs. sigh...might just have to let a mechanic that knows dc wiring take a look at it.
1 - 8 of 8 Posts
