1 - 2 of 2 Posts
i recently did the 5spd swap and now when i went to start the car nothing happens no fuel pump, no starter. i was told by the local shop that i need to eliminate the neutral safety switch by connecting two wires coming from the small computer under the steering wheel.
I Miss My BB2 :'(
does your fuel pump kick on when you turn the key? the neutral safety switch shouldnt have anything to do with that until you try to crank it. if you sort the safety switch problem out and it still doesnt work, try replacing your main relay or resoldering the wires inside of it. (thats usually what happens when main relays go out) if the main relay is fried then it will cause you to have the same symtoms that you described. (no spark, no fuel)
trust me on this.
but if you connect the safety switch wires then that should fix the problem.
1 - 2 of 2 Posts
