Sup guys...I'm bout 2 buy yokohama s drives 205\50\16...for my stock 5th rims...has any1 tried 225\50 on stock blades? I need the width for traction...I'm also dropped 2.5 inches....will this work or will I need wider rims like 16 x 7 ??
should work fine. your stock blades are +55 offset. i'm running a 17x7 +55 with 225/45 tires, lowered two inches or so with no rubbing issues. the only real diff in our setups is that your actual rim is .5" narrower, so the tire will bulge out just a bit more. regardless, our geometries should match up pretty close. i'd say go for it
oh and if you get new wheels and want to keep the 225's, make sure to get a pretty high offset, like +50 or +55. otherwise you'll start rubbing on your fenders and stuff.
^^^ thanks for ya input...
any others? any guys currently have this tire size?
