1 - 4 of 4 Posts
So lets start out by saying I am running a 4 plug auto P13 ECU in my 5 speed H22 Prelude. The issue is/was when I turn on my heater and or headlights the idle would jump up too far and I would get a bouncy idle which couln't be reversed. I couldn't set the idle low enough without a load so that it would stay below the 1100 mark with a load (at 1100 and above honda ecu's cut the injectors with the throttle shut for fuel economy) so every time I give it an electrical load I get the bouncy idle.
So after trying most everything humanly possible I grabbed my old Auto P28 that was fake JUN chipped and I removed two resistors and jumped one connection making it a manual ECU. I then plugged it in and started it up, then had to adjust the idle up a ways to get it right. Now when I turn on the headlights/heater it doesn't go crazy with the idle and start bouncing.
Now I am debating if I should sell the auto p13 and get a manual p13 or what? The p28's vtec doesn't kick in till around 6 grand and is a lot weaker than the p13's vtec although the p28 feels like it pulls harder before vtec than the p13.
Watever you do,ditch that POS P28.
Im just thinking it might have something to do with the P13 being auto, I heard somewhere that using the auto ECU can cause wierd idles. Thinking about ebaying the P13 and running the P28 till it sells and I get a USDM 5 speed P13
1 - 4 of 4 Posts
