1 - 2 of 2 Posts
i kno where the oil pressure switch it its under the oil filter but i need the oil sender so i can hook up my oil pressure gauge
bump need to kno asap
look on the head with it facing you from the front of your car. over towards the far left near the distributor, there is a bolt in the head that isnt holding anything together. remove that and replace the bolt with you oil pressure sender. that is where the dealer tests oil pressure at if there is a suspected problem with oil pressure.
1 - 2 of 2 Posts
