Hello I'm replacing my preludes tranny with a new to me tranny(m2s4). I'm gonna be putting in a new clutch along with a lighter flywheel for giggles. While I still have the new tranny out still should I replace any gaskets or seals? I've tried to do some research but all I can find is info on auto trannys. Kinda just seeking advice on what I should refresh and replace on this tranny before she goes in
Thanks!
Is the trans leaking now? If not you may be better off leaving it alone. Unless you're opening the trans to replace synchros or bearings or a bad leak, just clean it up and put ti back in.
While you have the rear of the engine accessible, I would personally check the rear main seal for leakage on the motor.
