1 - 20 of 37 Posts
I bought all the necessary parts for wet sanding and polishing my headlights today, but the only thing I'm concerned about is that Home Depot didnt have 2000 grit sandpaper.. only 600. Will 600 be ok to use or do I need something finer/smoother? The 600 grit feels smooth enough, but I'll leave it to you guys to decide.
Wow.. well, there's a huge difference between 600 and 2000.
Yeah, I figured Home Depot doesn't have it.. go to Lowe's or something..
I don't have any experience with wet sanding headlights.. don't know why you would do it, but I highly recommend you get the right grit.
I could see you getting away with 1800, but 600? damn.
HipHopHeadd
600 would not be fine enough IMO. But maybe someone else has more paint/ bodywork experience.
Don't use 600 grit, that's too ruff...Go to an Auto part store like Auto Zone and get some 2000 grit paper. If you have a buffer, it makes the job alot easier/better...Here is a lense I did the other day
Before
After
I got my 2000 grit from Pep Boys. i think it was like 5 bucks. good luck. mine ended up just as bad now (worse even) a few months afterwards than they were then :jehon:
I bought the full kit [headlight polishing kit] fromm autozone for $15.
It included the pads and pre-applied compound, all I added was a few drops of water. The difference was night and day, my lude is a 97 with 149K and I don't think that thows headlights were ever fully clean.
Other issue:
The paint shop that painted my front bumper got some on my headlight, what should use to take it off, I was told gasoline....
I just ran out to Pep Boys and got some 3M Imperial Wetordry sandpaper 1500 grit.. (2000 grit was sold out).. is 1500 too rough, or I'll be ok?
btw.. I'm using a dremel with a polishing wheel.
1500 will be fine. When you wet sand, don't put alot of presure onto the lense. Just kinda go with the flow and take your time.
Other issue:
Gas will possibly take it off. Try a little bit in one spot and see what happens. I usually just sand that off as well whenever I recieve lenses with overspray on them
alright, thanks for the tip. :emthup:
not a problem, just here to help out
Before
Sorry my old stock ones were in such bad condition. I am glad I went with new housings for my retros I had you do. They arrived back at my other house and I will be seeing them for the first time in about 2 hours from now. Thanks a million Brian.
Mike
[email protected]
Mike
[email protected]
It's not a problem, I've recieved worst lenses than that. I've gotten some that the whole lense was straight up yellow, so I didn't even bother to wet sand them, I just sold them off...
If you can locate a polish made by mequires that is called headlight restore. I think. Anyways, this is so much safer and just as effective as wet sanding and it only requires half the time and effort. It is a couple of dollars per bottle but I used it on my headlights and it worked great. The guy that owned the car before me tried to wet sand the headlights and needless to say scratched the lens all up. The polish fixed the scratches and made them look just as good as new.
Discussion Starter · #16 ·
I just got done wet sanding the headlights. they look alot better than what they used to be, but they're not 100% perfect. stupid dremel keeps leaving lines when I polish over the compound.
bangin' gears
buffing the inside of the lens helps alot as well.
has anyone here tried spraying clear coat on after wet sanding??? it really finishes the job. looks like a brand new head light, id highly recommend it to you all.
what type of clear coat do you use? I've been wanting to find out about this. I know it would have to be a certain type of clear coat for it to work
i thought off all the above and tried all of the above. the most effective was using plastx from meguires. others dont last long but the plastx plastic polish is still on and havent done anything it since.
1 - 20 of 37 Posts
