ok my rear drivers side turn signal doesnt blink.
not the flasher checked and replaced anyway
not the bulb checked and replaced anyway.
i get power to both plugs( the one on the quarter panel and at the light housing)
will not work with the other bulb and the bulb doe work on the other side.
the front blinks fast like the bulb is out but its fine. the hazards work fine with the one exception.
shoot some ideas at me cause im sure its a matter of time before te fuzz gets an attitude with me
thanks
Try jumping the ground. Take a pice of wire. touch one end strait to metal part of bulb and the other to a good ground. Does it work now? hum...
the bulb works fine. ive done enough testing on the bulb and wires from the plug to the bulb and it works fine.
Bad connection from the bulb to socket?
getting power and ground to the socket. gonna try a new taillight assembly and see what happens
Have you tried a new bulb? Or sometime the spring that pushes the + connection to the bottom of the bulb goes bad and wont touch the bulb.
