Been off this site for a while but thought I'd come back to write a short review on the eBay viton valve seals I purchased.
I think Diamondsleeper said something in a post about having lost faith in felpro valve seals, and I'll second that. My first experience lasted about 50'000 kms until my engine blew, but I had some top end burning for the time that it was running.
When I attempted my forged build I installed a new set of seals, (felpro) however my rings didn't end up seating properly and I had to pull it apart. when I dis-assembled my head I notice one of the seals was no longer locked onto the stem thus no seal at all for that valve. Also, all seals came off very easily and felt soft. (less than 5000km's)
When I pulled that engine and swapped in a stock B20a5, I again, installed a new set of seals (felpro again) because why not. Ended up having solid bad valve seal symptoms so apart came the head again.
again, I found a seal popped off and all seals felt soft (jacket/shield is rubber).
At this point you're probably thinking I suck at installing valve seals. Maybe! However.
I decided screw felpro and ordered some ebay blue viton valve seals, ad said "fits H23 and B20a5". Sounded a little weird to me but I went for it. Best decision of my life!!!
First off, the rubber simply feels great on the seals. I can't explain it, but you know what I'm talking about if you've compared viton to regular. Second, metal jacked/shield!! So friggen sturdy and clicked super nice when installing onto the stem.
Haven't burnt a drop of oil in 15'000 km's. (B20a5 block/head with B21 components, around 180'000km's) Sure that's not super high at this point but I've never driven my car without it puffing something so I'm over the moon. Highly recommend if you're changing your valve seals.
