1 - 1 of 1 Posts
I replaced the master cylinder recently. Later found that their was a vacuum leak coming from between the M/C and brake booster that wasn't there before. I tried replacing the seal that goes between the M/C and booster (comes with M/C), no luck. Tried using RTV on the flange of the M/C between the booster, no luck. Any Ideas?
Does the Booster seal around the shaft thats between the pedal and M/C.
I've heard they make rebuild kits for the booster. Could I have meased up a seal when replacing the M/C?
1 - 1 of 1 Posts
