redludesh said:
If so how did you do it?? Any help with intake manifold removal on an SH would be greatly appreciated, Thanks
first thing to do is remove your gas cap to relieve the fuel pressure because you will be removing the injectors and fuel rail.
Remove the intake and air box.
removal on an SH is a tad bit harder than on a base model. The oil filter is right in the way.
Remove the connectors for IAT located here:
Map (top) and TPS (bottom) here:
There is a black box under the intake manifold that you will need to take the connector off as well
then take off the IACV connector (may be easier to just unbolt it from the IM) and the wiring harness/clips for the injectors.
Remove the coolant lines from the Fast Idle (located under the throttle body. Remember which hose goes where.
Now start removing the vacuum hoses. REMEMBER WHERE THEY GO. It may be best for you to label them. Each hose has numbers on them like 13, 15...etc. Write them down, do what you have to so that you remember where each one goes.
Now you need to remove the fuel rail and injectors. Take off the 3 nuts that hold the fuel rail to the mounts. Slowly pull the fuel rail off the studs. There are plastic-like seals where the injectors go into the IM and they will fall out very easily.
I have found it easier to take the IM out if you take the top portion of it off. its just a couple bolts/nuts and it pops right off.
Next you are going to need to remove the nuts on the underside of the intake manifold. The best way to do that is by getting under the car. It likely that you will need to remove the oil filter in order to access the IM nuts. Anyway, take the bottom nuts off, then take the top nuts off. There is a bracket that goes from the firewall to the bottom of the intake manifold. One bolt holds that bracket to the manifold. Remove it.
this should get you to the point to where you can take everything off. Hope that helps.
