Hey guys, this is my cold air intake project. I also tapped all my intake runner for vacuum and re-configured a PCV system with catch can and VC vent to my new airbox. The airbox and plate is made and sold by my dyno tuner BOI Performance and the plate was machined specifically for my car.
Cold air runs through a 4" duct via large K&N pod filter in a high pressure zone external to the engine bay.
So far the results are less heat-soak induced loss of throttle response in stop-go traffic situations or hot days, but the dyno results are yet to be seen. I am expecting a little more torque across the range with a boost in top end HP, and this is what I have seen on other dyno runs that have upgraded to this setup. Subjectively, the low end response did feel better.
Test fit airbox:
Carbs off to tap IM runners, and finishing touches on airbox back plate:
New threads:
Modify the throttle linkage while I'm at it for adjustable throw:
Back plate fine tuned and fitted:
Refit carbs/mani to engine:
Fit the backing plate, and notice the shorter throw on the accelerator linkage:
Seal and dampen the air box:
Checked out the corner to clear the PCV VC vent fitting:
Box done:
Test fit airbox:
New threads:
Box done:
