1 - 3 of 3 Posts
Hey y’all I got a boosted h22 head with h23 block and before this happened I had a bad iac and one day I was driving and out of no where my cel came on along with a lil kick so I pulled over to check it out and couldn’t find anything Nd then about 2 mins away from home Nd it’s started misfiring really bad wouldn’t go over about 3k rpm so I thought it was the iac so I changed it Nd it’s still doing the same thing fluctuating idle Nd when I hit the gas it misfires like crazy unable to drive at all also I change my plugs not wires tho Nd cleaned my dizzy Nd my fuel pressure went up 10 psi for some reason but I lowered it back Nd no change any info would greatly b appreciated
Discussion Starter #2
Well I didn’t clean my distributor just checked it seems to be sparking
Have you check to see what the trouble code is? That is typically the first thing to do, not throwing an IACV at it.
1 - 3 of 3 Posts
