1 - 7 of 7 Posts
Hey eveyone, I'm new to the whole Honda and Prelude scene. I bought a 1990 Prelude Si 4WS, 5SP with a B21A1. I've been searching for a while and haven't been able to find anything about my problem. It has a check engine light on it and i got a list of trouble codes. I thought it was flashing a 5 which is mechanical problem with the MAP. I replaced the MAP, removed clock fuse for a few minutes, fired it up and the light came back on again. I'm guessing that wasn't it. I got back down and looked at my code again and now i'm second guessing myself. Here's my question: do you count the last "short" flash as part of the code number? It is flashing 4 slow flashes and then a 5th fast flash. Is this a code 4 or 5? if it is a 4 then apparently it is the Crank sensor, but I don't want to go replacing anymore parts until i know what code I'm actually reading. I'm not really used to this set up and any help would be greatly appreciated!! I did just find a thread where someone said that a long flash is counts of 10 and short flashes are counts of 1, so does that make my code a 41? the trouble code chart I have goes from 0 to 17. Please Help!!
Pipman
code 41 is Primary Oxygen Sensor - Heater circuit malfunction - o2 sensor/bad wiring
here is a list :
0
Engine Control Module
1
HO2S Or O2S
2
HO2S Or O2S{2}
VSS{1}
3
MAP Sensor
4
CKP Sensor{2}
Vacuum Switch{1}
5
MAP Sensor
6
ECT Sensor
7
TP Sensor{2}
M/T Clutch Switch Signal{1}
A/T Shift Position Signal{1}
8
TDC{2}
Ignition Coil Signal{1}
9
No. 1 Cylinder Position Sensor
10
IAT Sensor
12
EGR System
13
BARO Sensor
14
IAC Valve{2}
EACV{1}
15
Ignition Output Signal
16
Fuel Injector System
17
VSS
19
Lock-Up Solenoid Valve
20
Electric Load Detector
21
VTEC Solenoid Valve
22
VTEC Pressure Switch
23
KS
30
A/T FI Signal A
31
A/T FI Signal B
41
HO2S Heater
43
Fuel Supply System
48
HO2S{3}
yup, code 41. o2 heater circuit malfunction.
usually means the o2 sensor is shot.
there's a link in the FAQ sticky to the full list of trouble codes with better explanations of what each is.
Thanks guys for the info. The trouble code chart I had before didn't include codes 41 and 43. I stumbled accross prelude3G.com and was able to print out a flowchart for the O2 sensor. tomorrow at work i'm gonna pull it in and check out the sensor. Where's the best place to get one of those, just the local parts store? I saw that around here they are around $55. Is that normal?
Thanks again,
Pipman
Thanks again,
Pipman
for the price just get a universel one and cut the conector and soder it on the new one
i have the same 41 code and i have replaced my oxygen sensor with an original ntk sensor and i still get the code. i unplugged my battery for 10 after the install.. please help this has been bugging me forever!
check the wiring for damage.
and be sure that the sensor you swapped in isnt bad
1 - 7 of 7 Posts
