i have an 89 without abs and a 90 with abs. i have found out that the outer splines are different. so my question is will the inner spline of my 89 axle match up with the trans of the 90 model. i think the inner axles are the same but i just need some more opinions about it before i take everything apart and cant do it.
the inner splines are the same regardless of what year it is the outers are different 88-89 to 90-91 and this is all so in the 3g resource section
alright then are the axle lengths the same
New title is new
Yup.
yes.that info is correct.just use your old axels and everything will be fine.
