1 - 2 of 2 Posts
· Registered
Hello I have a 91 lude with a jdm h22a swap. Recently blew a trans and replaced it with a used one but now it seems to lock into the 5th/reverse column when I try to shift it in reverse. It will not go back to neutral unless done so manually on the shift linkage. Anything helps thank you👍
1 - 2 of 2 Posts
