Hi,
I just got my car back from the garage, he put a systhetic motor oil but there is a bit too much oil, about 3/8" over the normal oil level, should i make him remove some oil or is it ok with over level oil ?
Sorry for my bad english!
Maculosa
is it in between the lines or above? if its above take some out, if its between leave it. im not sure what "normal" is too you sooo. but it will slow you down at the very least.
Idiotic Thread Locker!
Yea, if it's much over the upper dot on the dipstick it should have a 1/2 quart or so drained...too much oil can cause your oil pump to overwork and overheat.
