Status
Not open for further replies.
1 - 10 of 10 Posts
how do i tighten my timing belt. i got it on and timed and all that good stuff. theres just play in part of it. and i dont want that part slipping on me
Rep me if you hate my ass
Do the tensioner-tightening procedure in the online manual. I did and it worked like a hot damn.
ludeicious if you dont have anything useful to say. why even bother saying anything..
and i know theres a tensioner its just my timing belt is still lose on one side. but on the other side. its perfectly fine. and i just cant figure it out...
Also - BEING CAREFUL NOT TO LET IT SLIP TIMING - you can hand turn the crank bolt a full revolution and see if that helps you retention it.
This is how i double check it's tensioned properly.
I did give you a useful piece of information. I told you exactly where to look to find the solution to your problem. Also if you look further into the searching part of what I told you, you would have found that the front part of the belt doesn't tighten up like the rear part does. Its just the way it is.
search, read the faq, follow the instuctions in the online manual.
he gave you useful info, just as the rest of us did. follow it
1 - 10 of 10 Posts
Status
