1 - 20 of 76 Posts
ok so since i have a bunch of threads going about this car ill do a first post with links to those threads and then from this point on i will update any projects or pregress in here. if this is not the way to go then somone please let me know.
main http://www.preludepower.com/forums/showthread.php?t=309569
climate http://www.preludepower.com/forums/showthread.php?t=317776
navi http://www.preludepower.com/forums/showthread.php?t=312295
brakes http://www.preludepower.com/forums/showthread.php?t=313214
panel http://www.preludepower.com/forums/showthread.php?t=311608
digidash http://www.preludepower.com/forums/showthread.php?t=308632
papers http://www.preludepower.com/forums/showthread.php?t=317250
Discussion Starter · #2 ·
so i got my new brakes installed up front today. i got OE replacment brembo's for 22 bucks each. but they were plain and boring shiny metal so i painted them red and added the brembo logo around the center hub. they turned out ok and should do the job just fine. pics are here- http://www.preludepower.com/forums/showthread.php?t=309569&page=3
^ how do you figure. i havnt got the pics yet to post so how could i fail to post them properly? try giving my original post another read
also please dont littre my thread with usless posts. if you want to coment on somthing ive don to my car or make a sugestion thats awsome i love feedback
but stupid, pointless remarks are just a waste of space. im sorry if that came off rude or insulting, it wasnt meant to.
Discussion Starter · #9 ·
so a little real time data from the navigator on my weekend trip to see my bro
distance one way
avg speed
time driving
distance ahead of schedule
no stops for gas
cruising speed(less than the majority of other cars)
thanks man. i have actually removed the "bells and whistles" couse they are anoying but i know what you mean lol actually i have found most of it through 3gcvc. he has found me most of the really cool stuff.
and yes there is more much more. but they are NOT going to be easy to find.
keep a watch in here as im getting a few more boxes in in teh next few months with more stuff. always good for a look.
Aussie Aussie Aussie
Need I say it again.. show off! ha ha..
Love th map light... What's the "corner pole" switch - sounds aggressive and what's the deal with the chrome guards... they go where exactly?
Oooh and what's the regrind on the cam?
Discussion Starter · #17 · (Edited)
im just showing what i have....:p
the map light is sick. the corner pole switch runs a device much like a power antenna. it telescopes up with a light or reflector on top to mark the outer corner of the front bumper opposite the driver. for tight parking situations.
the deal with the cam is.....no one knows the regrind specs. ill have to measure it to be 100% on what it will do. either way if i can jam it in my cyl head it will make some power lol
the chrome rain gaurds go on teh edge of the window on the door so you can roll down your window a bit when its raining and not get soaked. you have to actually remove the wondow track rubber to install them.
Discussion Starter · #20 ·
maplight installation
ok so here my option map light. after a good cleaning i had it shining like new. as far as install it pretty straight forward. you unbolt the mirror by removing the two philips head screws. now you have to run the wire harness down to the fuse box. to do this i pulled the A-pillar cover off and the suround trim on the sunroof. this allowed me to pull the headliner down enough to pass the wire from the door pillar over to the center. i then punched a hole through the center of the "hump" so it comes out between the two "fingers" on the map light mount. now bolted the mirror back up with the new mount under the mirror. re-installed the sunroof trim.
the harness is plenty long enough to go all the way down the pillar to the fuse box. i ran the new wires with the small harness already there and re-installed the pillar cover.
there is a spade terminal un-used in teh fuse box wich i plugged the cable into. pretty simple.
the actuall light portion unclips to allow access to the sunroof manual crank plug. damn honda thinks of everything lol
and the finished product
1 - 20 of 76 Posts
