1 - 2 of 2 Posts
Ok guys so its just like it sounds and I have researched first. The temp slider is on the hot side, but I get no heat at all. When I go to slide it over to cold it gets stuck around half way. The cable is connected, I just can't get it to move all the way to cold and you'd think since it's stuck on the hot side id at least get heat. Winter sucks to work on shit outside. It moves easily going to cold side till it just dead stops and I don't wanna force it and break any plastic parts. Any ideas whats up? I've seen ppl with this issue on here just not quite the same as mine. Here's some pics too. Oh and its a 2000 base, h22a4, the blower works, the controls to move it from the floor/upper vents/windshield all seem to work ok. Thanks in advance.
Electronic instrument Gadget Reflex camera Computer hardware Camera lens
Automotive tire Audio equipment Computer hardware Gas Machine
Car Vehicle Light Motor vehicle Steering part
Car Motor vehicle Vehicle Steering part Steering wheel
Administrator
Sounds like the heater valve on the bulkhead is seizing up. You can try spraying it with a penetrant and see if it will loosen up.
As far as no heat goes, possibly a clogged heater valve or heater core.
1 - 2 of 2 Posts
