1 - 4 of 4 Posts
so i had this problem before it gets progressively worse i thought it was from oil. I just checked oil and it is just above the first dot is that considered low? Last time i fixed it i added about 3 quarts i was pretty low i also took the distributor apart and messed with the ignitor coil.... i really dont get it it just started after my head swap my old head never did that with low oil... and also the engine is not stuttering yet, but i know that will start over time....
_
just above the first dot means it's just above the line where you need to fill it with oil. the top hole is the maximum fill line. put some oil in.
when you use your signals and your tach is on, does the tach stop working?
i added oil and now it will jump but its real picky as to when it does it this car confuses the shit out of me
_
yeah. same. all my problems have been electrical. this motor and 5speed trans are pretty damn good. and have taken a fair amount of abuse from me trying to learn how to properly drive the thing when i first got it. still pulls just like it did when i got it.
1 - 4 of 4 Posts
