1 - 20 of 25 Posts
so here is my problem. i got a alpine type-e 10" sub and i want to make a basic box out of 3/4 mdf. i was thinking of making a sealed one ( ported seems too hard) but i got a little confused with the box volume.
i pulled the specs and found out my subs sealed box volume is: 0.6-1.25 cu. ft
so heres the question, would the enclosure sound different if the boc was .8cu. ft compared to if it was 1.2 cu. ft?
how would frequency be effected ?
i thought it would be a simple weekend project to make but it is getting frustrating so please help me out here guys.
http://www.crutchfield.com/S-yPFWuav7jez/p_500SWE1042/Alpine-SWE-1042.html
that's the specs of my sub woofer ^^^
p.s. i listen to mostly hip-hop & rap so enclosure with low bass would be sweet
the bigger the sealed box gets, the lower its resonant frequency (and the lower your speaker will play down to).
a little sealed box will sound high and tight, while a larger sealed box will sound low and loose.
since you are putting the speaker in a pretty small cabin, i'd edge more towards the bigger side...
since you are listening to bass heavy music, i'd edge more towards the bigger side.
but most of all, i'd use the specs in some box-building software and see where the curve looks best.
i tried that...but the calculator i've always used suggests the speaker should be in a 6 cubic foot ported box...or (tho not recommended) a 8 cubic foot sealed box.
alpine and crutchfield must know something the mathematics experts do not.
so, if i trusted alpine and their giant window of a recommendation, i'd build a box that was 1 cubic foot on the inside.
IMO Alpine's always like their larger recommended enclosures, and they definately like ported over sealed. Go with 1.25 sealed.
I have box design software, if you want me to mock somethin up or find you a cut list, just pm me.
- Shane
  • Like
Reactions: dawg316
- Shane
or, if your pushed on the matter and can't descide, go with the middle, and make it 1cu.ft. all will sound good given the sub is in proper order, and the amp is wired correctly.
thanks guys, im probably gonna make a nice .8-1 ft3 box. would depth matter or dose volumer matter only ?
Shape shouldn't matter aside from having the sub actually fit inside the box and clear the back. Make sure to account for the woofer's actual displacement when making your size calculations... a 1 cu. ft. box is actually 1.3 cu. ft. when you put a sub that displaces .3 cubes in it.
Volume is really your only concern however.
If you want to make a ported box, I found this calculator to help me design my first ported box and it worked very very well for me.
http://reaudio.com/speaker_box/LPort_Box_Calc.html
Now as far as tuning frequency and all that goes, I never had a very firm understanding of that, but that calculator will give you a cut list for whatever you want to do, assembly is pretty easy assuming you have some basic 9th grade wood shop skills.
very nice calculator. great find.
p.s. good thing i dropped wood shop in grade 10 instead of grade 9
that calc is nice if you know what volume box you need to have.
alpines giant ass window doesn't give us a very narrow place from which to start, volume wise....and volume calcs keep spitting out 8 sealed cubic feet which is 6400% to 10,000% bigger than alpine suggests.
so, if you stick with one foot, that calc will design you a nice box.
but god only knows how your speaker is going to sound in it.
With a quick calc (using all the available driver parameters) I reckon that would work well in a vented box of 30 litres, one vent of 3" and 16cm long (or any variation to get that equivalent) (which is tuned to 45Hz).
A sealed box of 27litres would work but won't be as solid a sound nor as loud.
Will give a flatter frequecncy response but TBH in a car the vented would work better.
Could give you other options easy enough if you want them.
metric.grr im canadian and i hate it. if somebody can draw me up or sketch me up a blueprint for a box i would much apriciate it.
Actually if you give me two mins I'll upload the freguency plot of both those options.
Sorry but I'm taking time out to do the difficult things and you moan about doing a very very simple conversion .................. :eek2:
Anyway for what it's worth..
The box needs to be 1cu.ft
So approx 13"x13"x13"
Not that I'd make a square box but that's up to you and where you want it to fit.
Port needs to be 3" and 6.5" long. Best positioned in the front panel away from the driver.
Yellow plot is the sealed box, the green is the vented.
Discussion Starter · #17 ·
sorry im just frusterated right now. i no im being an ass hat right now.
thanks for the info
You'd be better using a shorter port length and tuning it around 45Hz rather than 37Hz.
And making the enclosure slightly bigger.
what software are you using?
my old standby (http://www.bcae1.com/spboxad2.htm) comes back with 7.9 ft^3 sealed and 5.9 ft^3 ported (port being 4"x11", basically) when i plug in a fs of 33hz, a Qts of .66, and a Vas of 1.165384 ft^3.
other calcs i used in the past came up with similar numbers.
i'm interested to know what you used...and what data you found/entered (i had to go looking for the fs).
1 - 20 of 25 Posts
