1 - 11 of 11 Posts
Tax Season Maniac
Just recently my car studders whenever I press on the accelerator. First it studders then "jumps up" (sometimes I get the studdering followed by a big jerk before resume normal acceleration) . I'm thinking it is fuel/air related.
I'm thinking of replacing the fuel filter first then tackle on to other fuel related parts. I also plan on cleaning out my IM for any possible carbon build-up. Am I on the right track?
-D
sounds like textbook clogged EGR hesitation to me with the information given. i would just clean the valve, ports, and change fuel filter just because..
iamNOTerator
you're on the right track, you should clean out the throttle body and air filter while you're at it, it also sounds like you need a tune up. Whens the last time your spark plugs and distributor cap where changed?
i would check your ignition and starter stuff first so you dont have to spend any money. clean the crap of your throttle cable too. make sure to grease a little bit. that helped me.
Tax Season Maniac
I may use Sea Foam to clean out my IM.
Last tune-up was done in April '08.
Then my vote is EGR. Take off the egr valve and look inside. If its caked with carbon then you have a diagnosis.
Just say no to sea-foam.
Tax Season Maniac
Actually, there was a crack on the distributor cap. There was a lot of moisture inside and the rotor was done. Replaced both parts...no more hesitation.
huh thats interesting, glad you fixed it.
H22 Accord with same problem
hi i have the same studdering problem with my h22 i think it may be my egr valve what should i clean it with
1 - 11 of 11 Posts
