My name is David, but I go by Milo. I'm 18, a professional welder and mechanic-in-training. I've had my Prelude for about a year and a half now. It's a 1990 Si 2.1
https://drive.google.com/folderview?id=0B7oZGjaPFb9xY2kzazBiM0p5U3M&usp=sharing
These are all the pictures I took of it before it died.
I bought the car with 144k miles on it. It's condition was mint! Super clean interior; no cracks, tears, missing carpet or anything wrong with it. There was some minor body damage from shopping carts and the Si 2.1L badge was gone. Car ran amazingly. No cruise... My first vehicle.
Bought it for 2500$. First thing I did was replace the entire stereo system. Plugged in an aftermarket single DIN radio and put in excellent speakers. Then installed two aftermarket radiator fans.
Moved away and then went to welding school. One day, I came outside to get an item and saw the damage to the front left fender. Someone hit me and ran. Got money from insurance and used it to repair things on the car. New alternator, air filter, cam seals, timing belt, water pump, LED lights, valve cover gasket, and steering wheel. (yes I bought an eBay steering wheel, don't judge-will replace)
Started installing all the new stuff! Got the alternator in, some LED lights, valve cover gasket, air filter. Then my throttle position sensor quit. Took forever to get my replacement, then installed it. That same day, I went back towards my hometown. Car was running great! In the middle of NOWHERE-engine stalls. I'm freaking out. Realize my oil temp was straight up for no reason. Going 75 and my engine overheated? Pulling over...open the hood. Coolant overflow is all the way up on the dipstick. Vaporized coolant everywhere. I'm so confused. I had a dummy moment and opened the radiator cap thinking it'll help. :wzbigcry: Don't need to go into detail...
I'm thinking, okay everything is okay. Waited for the engine to cool. Crank her up and oh my god...the terrible sounds...I had to put on a little gas to keep her running at all. Knocking sounds as if the lifters were hitting the cover or the rods were messed up. I still don't know. Let it die. Took forever as the car tried to stay on. The RPM's going up and down. Got my dad to come pick me up with a hopper.
He told me to crank it up and it does the same noises. He is standing there speechless like me. Then I see it. That last time I cranked it, a rod must've punched through the oil pan. Car was dead. Oil everywhere.
Note, I have not opened the valve cover or removed the oil pan to look at the state of the motor. I had to be back at my house for school. Bought a 2015 Ford Fusion SE dirt cheap with my perfect credit. Now I need your help. What should I do first, and what do you think?
