1 - 13 of 13 Posts
Hello)
My name is Antony.
Im from Moscow, Russia.
I am 22 years old. I work as an engineer, studying to be an engineer :)
I love vodka , bears, balalaika and build Prelude 5gen stance)
Prelude I bought a year ago.
Spec:
Wheels:
- Prodrive 9j ET+35 R17
- Bridgestone Potenza RE001 205/45/17
Transmission
- M2Z4 LSD.
- Exedy Stage 1.
Exhaust:
- Collector Mugen Jasma.
- Catback Mugen Twin Loop.
Intake:
- Stoke.
Suspension:
- Tein Type Flex.
- The front strut of the Type-S.
Brakes:
- Front: Carriages under EuroR 300th disc. Disks company R1Concepts Series ELINE (Metal G3000) + Ceramic pads STOPTECH.
- Rear: Stoke.
Exterior:
- Wide OEM sticky.
- Fetish pad on the hood.
- Grid Honeycumb prelude.
- JDM fog lights.
- White turn signal repeaters.
With English is bad, correct where it is not properly written, please.
Season skated " I bought ." This season began to build a stance on the static.
The first step took a fiberglass body kit, withdrew lights DEPO, took USDM fog lights.
Ordered from Japan coilovers Tein Type Flex, stock bumper front / rear, wide lips OEM, honeycomb grille, JDM fog lamps, cover on to the hood.
Next Prodrive wheels were purchased in the parameters P17 9j ET+35. They put tires Bridgestone Potenza RE001 Adrenaline 205/45/17.
My StanceCat :D
Currently prelude assembled. I look forward to painting. I will be completely painted in black.
In preparation for painting cars will roll out the arches and clean up problems with the body. Immediately after the dyeing machine completely understated and fitting fitment.
Friends, tell me, I want to make a collapse of the wheels 5-7 degrees. At the same time I want to keep 4WS system.
In Russia, very bad roads with respect to Europe or the States , on the planning of the season to achieve clearance of 4-5 centimeters. The next season will be on the air.
Stay Luding, Bro!
У нас еще нормальные дороги относительно провинции, но и там есть отмороженные стенсеры))
Discussion Starter #4
Hello.
Long time no write.
During that time, little has happened to make. Forever is not enough either time or money. :)
I put long since acquired, climate control on JDM version Prelude.
Acquired swap kit cruise control for MT. Interested manual installation. Previously he stood tiptronic with park assistance now M2Z4. Please provide the link to manual.
The forum recently stumbled on a cold intake AEM v1.0 at a very low price of $ 100. Took immediately, as the intake of the type-s could not be found for half a year. Rarity :(
Set. In my opinion, the car began to go on VTEC better.
Friends, as building a very low static, wondered how to make a large negative angle? Our suspension (4WS) with maximum understatement, allows you to make 2 degrees front and 4 rear.
I came up behind how to make 7 or even 10 degrees without changing levers. If it works, be sure to write about it.
And in front, but to cut leverage not found a way.
I will be very happy to prompts!
Recently I think about swap on K series.
Interested in such projects, the availability of spare parts and so on.
I did not find the engine mounts for 5gen on K series. Is there a forum similar projects? In Russia, there are only projects swap 1JZ-GTE in 4gen and J32 in 4gen and 5gen.
It is also very interesting hybrid projects VTEC K20 + K24.
Thank you in advance for your help!
Discussion Starter #9
Hello)
Finally, the replace color on my car) Painted in the garage overnight, with friend.
Option time, so as soon as a lot of work on the body.
This season ended as it is.
Discussion Starter #10
Sparco NT 9j ET+20 and Triangle Group TR968 205/40/17 on board!
Discussion Starter #11
Discussion Starter #12 (Edited)
Hi All!
During my silence on the forum, my car was radically named.
I replaced the motor. Changed the interior. Changed the suspension. Restored the body and painted it!
Discussion Starter #13
I will tell more in detail.
Three years ago, I decided to take the car. A lot of places requested attention. And I decided to do it.
I started with the fact that my own blacktop was filmed. He was bought on the replacement redtop 220 horsepower. A body was completely disassembled and sent for restoration. Not without problems, the rear wings were completely replaced and sills. After the car was sent for painting in black.
Parallel to this, a red interior was ordered from Japan. I think that this is the most beautiful interior of all that were set. The torpedo on the left hand drive, of course, did not get up. By this, I bought the usual black torpedo and collected it. Together with the steering wheel of a Honda Civic EP3, it all looks very cool!
When I was given the body, I started to build the car. It was the longest process. When he came to the end, I thought about the appearance of the car. I did not like old wheels, and I sold them. The replacement wheels were ordered XXRWheels 968 model in the parameters of 10.5j x 18 and tires 215/35/18.
The old racks Tein Type Flex did not suit me either. On this new racks D2Racing Sport were bought. To them were bought custom spring 30 and 25 kilograms with a height of 90mm. With this, I started building my setup.
Now I need adjustable levers in the front and shortened steering knuckles. In our country, I can not find this unfortunately. If anyone can share a link or contact, I will be very grateful!
1 - 13 of 13 Posts
