1 - 10 of 10 Posts
Seems to me my back rotor is squeeling like crazy, it just started acting up, i think a rock is between my breaks and my rotors because my breakpads look new... it started happening when i was driving. any idea's?
Thanks Deric
You mean its making a "screeching" type of noise? Could just be time for new rotors and/or pads.
This happen to me once, not sure if same deal with you but i had a lip on my brake pads(maybe rotor? was awhile ago) that was causing a noise similar to a plane landing... dunno, maybe check that out.
i am going to take my wheels off and then my calipers, if its the break pads then i will replace but otherwise its very difference... its going with the wheel. like it squeels 3/4ths of the wheel rotation and then lets off and then does it again in a loop type phase.. very weird
sounds like you need some new brake pads. I'd advise to get theme asap before it starts cutting into your rotor which will cause more problems
Sleeper Needs Boost!
I concour with this
if its uneven like that you should consider turning your rotors too.
1 - 10 of 10 Posts
