Do you have the stock recommended tire size on your car?
nope, i have 14" tires
That's why your speedometer is off. The difference in tire size will make your speedo read wrong. I'm not sure if there's a different gear you can swap into the trans to correct it for the tire size....
if u have the stock wheel recomend then its ur vss
