I'm building a custom offroad creation w/ the engine rotated 90 degrees and samuri axles at both ends on coilovers.
I need to get rid of the body wiring and end up with only the engine managment wiring because this is all thats needed to run the vehicle.
The engine/trans will be located in the approximate middle of the wheelbase, cam drive end to the rear, and driver in front of the trans at the front of the chassis for the ability to see the terrain. The original PS pump will power full hydraulic steering on front. A full tube chassis will support the engine, locate the axles, and protect the driver.
The B20 PCI provides good power, compact auto package, and the ability to run upside down if required.
Any help with wiring diagrams or wiring mods to remove emission components will help!
