1 - 11 of 11 Posts
Are there any tell tale signs of when wheel bearings need replacing. How do I know when do replace?
Right now it kind of sounds like humming but only at 20mph and around there. Above 20 it goes away. Below 20 it's there but not too noticeable.
Youll hear kind of a wailing humm. Kind of like if your humming loudly with your mouth closed. Try it. *laughs*
I had to get my rears done because I sounded like a plane landing whenever I slowed down.
The previous owner told me she had the rears done at 70,000. I don't think the fronts have been done yet. Other than the humming my car also gets bad vibration coming to a stop and out of a start but once I'm going it's hardly noticeable.
you will have the humming noise as stated above. when mine went i noticed when the wheel was turned more towards one side it would hum and if i turned it toward the opposite direction the humming would stop. i replaced my left rear last summer and just finished doing the right rear a couple weeks ago.
The front wheels have bearings too right, not just the rears? I hear loud humming when I turn the wheel but It's a different humming def. from the tires because they're winter tires and taking hard turns with them makes them scream.
yeah the fronts have bearing as well. hope that is the rears because the rears are much easier to replace then the fronts
well i had to replace my rear right side bearing cost me $160 for the bearing from honda but i got it for $100 with a shop discount.. anyways it was rumbling and the hole back of my car was jumping at anyspeed.. especially when im 60mph I sounded like a plane, especially on the highway.
They had somekind of aftermarket prelude bearing for $70 at autozone.. but I wouldnt trust anything else then OEM for a bearing.
P.S. when you change em.. make sure wherever you change em.. you tighten the big ass bolt with high pressure gun and such..
1 - 11 of 11 Posts
