1 - 4 of 4 Posts
the 'lude makes me poor.
I would talk to precision about that. I personally don't enough of when to run, and not when to. I know I am not running one on my journal bearing t4, but there are some guys that run small t3's that need to use them.
the kit should have come with whatever is needed to be run.
but typically, if the oil feed line is 2an or 3an, you dont need to run a restrictor, usually. if the feed is a 4an, it definitely should have a restrictor.
often times, the fitting itsself is the restrictor, or sometimes the turbo center housing has a built in restrictor
Ditto.
Also you can contact them just to be sure about your application. If you have a ristrictor when it's not needed you WILL do more harm then good. I would double check it's better safe then sorry. -3 line will work fine IMO
1 - 4 of 4 Posts
