1 - 4 of 4 Posts
Hello all, I've been searching for the answer to this for awhile and can't seem to find the answer.
When buying rear aftermarket sway bar bushings, do i purchase the 23mm? As shown here? Or does the SH use a different one?
Thank you, here is the part in question.
http://www.energysuspensionparts.com/16.5122
Hey, when I looked up the official honda part numbers between base and sh they both listed as the same.
So I think its safe to assume that unless you have changed to an aftermarket sway bar with a thicker diameter you will be able to use those just fine.
The part number from honda for the bushing is
52315-SS0-010
Also, that stock part number fits on all preludes from 1992-2001 both automatic and standard.
Discussion Starter #3
52315-SS0-010
I didn't even think to compare the OEM part numbers, thank you.
1 - 4 of 4 Posts
