1 - 1 of 1 Posts
Does anyone know where to find sensor running voltages for the tps and map sensors?
Im looking for desired voltages at idle to see if perhaps some of my sensors may be bad.
Im getting 1.14V MAP at idle (850) and a reading of .47V with 0% TPS.
Does this sound correct?
Every test I see is to test continuity between ports on the sensors and at this point all I have is datalogs to check...
I'm looking everywhere and not seeing anything.
Other items that would be good to know:
Target Intake Air Temperature at idle
Target Engine Coolant Temperature at idle
Target Battery Voltage at idle
1 - 1 of 1 Posts
