1 - 2 of 2 Posts
My 93 lude has a auto tranny and i wanted to get some idea on how much i could possible sell it for. I just wanna get some numbers. It is practically BRAND new, i got it rebuilt about 1k miles ago. That cost $2300... i know it was a dumb thing to do but my dad insisted. Also, could i get the average cost of a manual conversion, ALL materials needed. Thanks
The search feature is ur friend
:tongue2: here you the parts needed
From a thread located in the 4th gen section. Goodluck with ur conversion im doing mine soon as well.
4th gen Auto to Manual Transmission Conversion
Parts List
Transmission
Flywheel
Clutch assembly
Slave cylinder
Clutch master cylinder
All lines and dampener from master to slave cylinder
Includes-- 1: line from master cylinder to dampener
2: dampener, bracket and bolts to hold to fender
3: rubber line from dampener to adapter on transmission
4: adapter and bolt to hold to transmission
5: line from adapter to slave cylinder
6: bolt that holds rubber line to adapter(banjo-bolt)
Starter for manual tranny
Drivers side CV shaft and intermediate shaft
Transmission mount and bracket
Speedometer sensor (salvage yard may leave it on the tranny)
Shifter cables, holding clips, clevis pins and cotter pins
Shifter cable bracket for tranny (salvage yard may leave it on the tranny)
Shifter assembly
Shifter boot assembly and shift knob
Clutch pedal assembly
Both switches for clutch and their plug-in connectors
Brake and gas pedal assembly
30 Amp Relay
Bolts Needed
Transmission bolt that goes through starter and bolt below it(the two longest bolts)
Flywheel bolts
Pressure plate bolts
Slave cylinder bolts
Intermediate shaft hanger bolts
Transmission shifter bracket bolts
1 - 2 of 2 Posts
