21 - 24 of 24 Posts
Discussion Starter · #21 ·
alanoneil said:
It doesn't matter which is "first". Where is the beginning of a circle? They're all "first"... Or do you mean because it's closest to the distributor? because that doesn't really make a difference either.
Again, did you check the plugs for fouling?
plugs should be good, i jus replaced them like 2 months ago with an oil change. The plugs jus look like they have been washed with gas.
Discussion Starter · #22 ·
im wondering would a clogged egr cause any of theses syptoms?? when i shut my car off it leaks gas back out the carbs. I really have no clue what the hell is goin on i thought i fixed the problem but then nope. I really need some knowledge here.
Discussion Starter · #24 ·
BUMP this question???
21 - 24 of 24 Posts
