1 - 7 of 7 Posts
Love the power of H
Ok i know s2k clusters are better and more common. But i can get an rsx cluster for dirt cheap and i was wondering if any one has tried to put one in a lude. If any one has pics or a wright up or anything let me know.
wouldn't be worth it...redline is different, and the display isn't even as pretty as it is is in the lude. Too much work to say the least for I would say little difference
agreed. absolutely not worth the time, trouble, and expense.
if it's a 02-04 it's just have to cut and splice also you will run into the same issues as the S2k with the speedo reading wrong and the temp gauge going to hot after 30 sec. the 05+ RSX clusters are canbus and gets the signals direct from the ECU's
F-Can..
1 - 7 of 7 Posts
