1 - 20 of 27 Posts
you can use a tool called a nut remover to get it out ... but if your in a tight spot you can always drill the head of the bolt untill it breaks away from the rest of the bolt and after removal of the head just turn the bolt out with a vice grip
just make sure you start drilling the center of the bolt with a 1/8 and keep steeping up untill it come off
good luck
P.
Memento Mori
Try buying a cheap socket 1mm smaller and hammering it onto the bolt head, works sometimes.
to the OP:
your only real chance is an ez-out designed for the bigger bolts. it's going to suck, and there is a fair to middle chance it won't work, but really you have few other options.
if you have the room and a welder, you could weld a nut to the top of the bolt head. weld it from the inside (the threads of the nut) and really burn the fuck out of it. once it cools, the bolt will probably be more likely to let go of the block, and the new nut edges give a wrench something to bite.
welding a nut to the head should be your last restort as it will harden the head of the bolt and you cant drill it
but hey whay do i know i just do this stuff for a living :huh2:
bully for you!
i apologize for being unable to ascertain your obvious superiority over all others on this site in your previous seven posts.
i'll refrain from posting, so that all may gaze upon the wonderfulness that your experience will grace us with.
Memento Mori
To take some tension off it you could try torquing all the other head bolts to 55ft lbs following the factory tightening pattern but skipping that bolt. The head gasket has a little give and you may be able to crush it more that way.
toguetastic
i have a set of sockets... maybe you guys are talking about the same type of thing... but anyway i have some sockets i got from craftsman that have teeth inside and they are reverse threaded so you tighten it on by loosening against the bolt. they bite into the bolt head/nut really deep and have literally never failed me before. i honestly think they would even work on a perfectly round bolt head.
are these what ur talking about hondamonster? if not im sure that these would do the job.
http://www.sears.com/shc/s/p_10153_12605_00952062000P?vName=Tools&cName=Hand+Tools%2C+General+Purpose&sName=Bolt-Out%2C+Taps+%26+Dies
Boxxy Is Back
yah, love these things. i have a set and they havent failed me yet.
1 - 20 of 27 Posts
