1 - 14 of 14 Posts
I was given a 1992 Honda Prelude yesterday, It has rust between the door and the sunroof, the front right part of it has a dent, and that's about the only problems.
I really, really like this car, I already had it survey'd by my mechanic for issues, putting it into the shop this week for 2600$ in electrical work, tune-up, ect, but I was thinkin about sinking some cash into it for customization
Body kit, paint job, ect.....
Only problem is, it has 185k on it, is it worth it?
How much would that cost? including installation, and if I switch it to Vtec won't I lose my shifter?
unless I could get financing on the new engine I doubt I could afford that ;) or I'd have to scrap the body work for awhile, which I really don't want to do, it's got a shitload of oxydation
get the car sturdy body wise before you break into the engine. if it's in good running condition now, i wouldn't mess with it either.
nice pick up though :)
mine's getting to that number i think i'm at 174XXX but i could be off by a little
only think i have problems with is a little blow by and another small oil leak from somewhere i can't find
oil pan gasket, thats the leak that led to my h22 swap, haha
::Decepticon make-over::
Well as long any noboby mistakes your corrosion for your paintjob, you should be ok. Now instead of spending 2600 on mechanical work and crap, you should really consider putting an entire new system in there so you're not paying for that service twice. Also if that isn't possible do the body work then put the chassis away until you're ready to do the swap. It is entirely up to you.
do you have any pics to let us c the car
before you get it looking good u better get it running right. it sucks to have a perfect body on a car that you cant drive. but i guess it would look good sitting in the drive way! just buy a whole jdm front end and you will have everything u need
1 - 14 of 14 Posts
