1 - 3 of 3 Posts
Can any describe or link a how to on installing rear lower sway bar?
Or maybe post a pic or 2 of what it looks like after being installed on a 4th gen???
Thanks...
Memento Mori
There is no upper sway bar, so it's only called a rear swaybar. Your car has one stock so installing a new one is pretty easy, just take the stock one off and install the aftermarket in it's place. The new one should come with all the hardware you will need.
There's most likely 4 connection points. One at each wheel, and two bolting it to the chassis.
Unbolt, remove, replace.
1 - 3 of 3 Posts
